REVIT 2019 Dynamo 2.03
I am trying to ovveride color elements.
After working on warnings and skim through elements and working on the list I was able to match
the exact number of elements retrieved with a color to be assigned.
So I am coming to graph with 2 lists, elements and colors
Than I worked on Archilab solutions as a base but I do not know why
it does not accept.
Here the script:
IN[0] is an element,
IN[1] is a color from the Color
clr.AddReference(“RevitAPI”)
import sys
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
def OverrideColorPattern(e, c):
gSettings = OverrideGraphicSettings() -
gSettings.SetSurfaceForegroundPatternColor(c) -
gSettings.SetProjectionLineColor(c) -
gSettings.SetSurfaceBackgroundPatternColor(c) -
UnwrapElement(view).SetElementOverrides(UnwrapElement(e).Id, gSettings) -
return e -
ele = UnwrapElement(IN[0])
col = UnwrapElement(IN[1])
try:
errorReport = None -
output = [] -
i=0 -
while i < len(ele) : -
C=col[i] -
E=ele[i] -
TransactionManager.Instance.EnsureInTransaction(doc) -
output.append(OverrideColorPattern(E,C)); -
TransactionManager.Instance.TransactionTaskDone() -
i=i+1 -
except:
import traceback -
errorReport = traceback.format_exc() -
if errorReport == None:
OUT = output -
OUT = errorReport
I got this error
Secondary I would love to be able to use the ovveride element color node, but
also that one I am not able to fill it properly, maybe I just awake dumb today.
Cheers.
