Override Graphic Settings - View Template - Cut Patterns - Background
Hello Everyone,
I am trying to set the background cut pattern and color for multiple elements in a view template. I started the attached, but I am stuck as to how to designate the override to background or foreground.
Thanks,Override Graphics Settings of View Template Categories.dyn (13.5 KB)
I don’t know how to use Python, but I found this thread:
Would there be a way to incorporate this into the workflow above?
@cescobar, the problem in your code is that you are feeding a View Template instance into a node that expects a View.
If you desire to modify the cut pattern of a given category in multiple views you can set up a View Template with a Visibility/Graphic Override and apply it to the desired views to achieve it. And I believe using Dynamo would be counter-productive if not at all unfeasible.
Hope it helps.
Thanks David.
Our office is transitioning to Revit 2019 and I need to adjust dozens of templates and they all require similar adjustments. I was hoping to be able to adjust the items I wanted in multiples templates at once.
Oh, I understand… Digging quickly through the Revit API Docs I wasn’t able to find a way to create or modify View Templates, so I think they are not accessible via the API, therefore inaccessible via Dynamo / Python (I could however be wrong, for my knowledge/experience with the API is not great).
And, as haven’t mentioned before, in the post you quoted before, the implementation is destined for modifying/creating materials and wouldn’t work for your situation.
And, excuse my curiosity, but what happened with your templates when migrating to R2019? I haven’t noticed any problems with mine so far (although mine are really simple).
Best,
David
David,
We want to take advantage of the dual patterns to be able to show phasing and also the materials within categories such as walls, floors, ceilings, etc. Below is our goal:
The script I ran was able to modify the template walls, but only the foreground. So when I run it, this is what I get:
It would be great if I could find a way to change the background cut fill pattern for a few categories at once for many of the view templates.
Christian
Christian, I was wrong. After you mentioned your script worked partially for your purposes, I realized the API sees the ViewTemplate as the same thing as a View instance, therefore, it could be done. Also, the problem your script faces is that the Dynamo OOTB node for Graphic Override does not include the Foreground and Background property for patterns that came with the R2019. So, based on my previous code for modifying Materials, I the developed the one that follows, and I believe it suits your needs.
#PROTO_View/Viewtemplate  Modification by category  v1 (Color and Surface Pattern control)
# by David DĂłria (arq.david.doria@outlook.com)
clr.AddReference('RevitAPI')
### INPUTS
template = IN[0]
category = IN[1]
forePat = IN[2]
foreColor = IN[3]
bkgPat = IN[4]
bkgColor = IN[5]
def ToRevitColor(dynamoColor):
	return Color(dynamoColor.Red, dynamoColor.Green, dynamoColor.Blue)
#Avoid instance input problem
if isinstance(template, list):
	template = template
else: template = [template]
if isinstance(category, list):
	category = category
else: category = [category]
if isinstance(forePat, list):
	forePat = forePat
else: forePat = [forePat]
if isinstance(foreColor, list):
	foreColor = foreColor
else: foreColor = [foreColor]
if isinstance(bkgPat, list):
	bkgPat = bkgPat
else: bkgPat = [bkgPat]
if isinstance(bkgColor, list):
	bkgColor = bkgColor
else: bkgColor = [bkgColor]
### CODE CORE
try:
	for t, cat, fP, fC, bP, bC in zip(template, category, forePat, foreColor, bkgPat, bkgColor):
		#Create the OverrideGraphicSetting instance
		over = OverrideGraphicSettings()
		#Set foreground cut pattern
		over.SetCutForegroundPatternId(UnwrapElement(fP).Id)
		#Set foreground cut pattern color
		over.SetCutForegroundPatternColor(ToRevitColor(fC))
		#Set background cut pattern
		over.SetCutBackgroundPatternId(UnwrapElement(bP).Id)
		#Set background cut pattern color
		over.SetCutBackgroundPatternColor(ToRevitColor(bC))
		t = UnwrapElement(t)
		t.SetCategoryOverrides(UnwrapElement(cat).Id, over)
	OUT = "Graphics Overriden!"
except:
	OUT = "Oops! Something went wrong"
The file is in Dynamo 2.
PROTO_View Template Modifyer.dyn (11.6 KB)
Hope it solves your problem.
Best,
David
David,
This is excellent! Thank you so much. I’m very new to understanding any of this.
Do you know how to set an override to none? Like if I don’t want to override a specific element in one of the “in” categories.
Thanks again,
Christian
You could copy the Python node, open it and delete the particular line of code you’d like to ignore for the category you are feeding in the IN[01] (the operations are commented and should be easy to identify).
Also, if the previous post solves your problem, I’d appreciate if you mark it as a solution.
Best,
David
David,
Thank you. That’s what I ended up doing.
Next step is for me to learn how to combine all the categories into one to the input. I tried to do list and list.map, but to not avail.
Thanks again for your help.
Christian
Hello @David_Doria
I have similar problem as @cescobar had . I want to use the foreground and background overides, but not assign them to view templates but rather use them in View.SetFilterOverides node. The node I found only let’s me change the forground color and pattern.
I would be glad if you could help
Hey, @Peter_Heldes
The following code / script will help you achieve what you want. A simple adaptation on what I had before does the trick. Instead of passing categories, you should pass a Filter element, such as the one you have already set up.
#PROTO_View Category Filter Override  Modification by category  v1 (Color and Surface Pattern control)
### INPUTS
view = IN[0]
filter = IN[1]
forePat = IN[2]
foreColor = IN[3]
bkgPat = IN[4]
bkgColor = IN[5]
if isinstance(view, list):
	view = view
else: view = [view]
if isinstance(filter, list):
	filter = filter
else: filter = [filter]
	forePat = forePat
	bkgPat = bkgPat
	bkgColor = bkgColor
### CODE CORE
try:
	for v, filt, fP, fC, bP, bC in zip(view, filter, forePat, foreColor, bkgPat, bkgColor):
		v = UnwrapElement(v)
		#t.SetCategoryOverrides(UnwrapElement(cat).Id, over)
		v.SetFilterOverrides(UnwrapElement(filt).Id, over)
except:
PROTO_View Filter Modifyer.dyn (28.4 KB)
Hope it helps.
Thank you so much works perfectly :slight_smile: I have one more questions. If I want to apply those overrides to multiple views and insert list of views into the first input then I have to match the list size od the colors and patterns right ? I did it using List.OfRepeatedItem but hen it makes it messy do you know of better way around it ?
Hello everyone,
I’ve tried all .dyn files but because of dynamo version some nodes doesn’t do the “trick” and because of my beginner experience I couldn’t tried.
BUT, if @David_Doria or anyone knows a different aproach for my issue, i’ll be glad for your help.
Here’s my struggle:
I have a technical design (image Left) with different foreground cut patterns by material / wall layers:
And i need to overried PATTERNS by MATERIAL to assign different solid colors to several materials in a certain view (image Right).
I’ve tried Revit PARTS and then filter then by material name, and it works BUT it’s really painfull if i change walls or any other procedure.
The big issue is to have a script that OVERRIDES Cut Patterns by Material in a specific View and do not change the entire model, because i need those two types of views (“original” and “override”).
I’m working with Revit 2023 an Dynamo v.2.16.1
Thanks.
