Override Element Color depending on Project parameter value intervals
Hello! I’m working on my master thesis where one of my objectives is to color code certain elements depending on how certain project parameters fall within value intervals. This meaning, for example, if a parameter has a value between 1 and 2 it colors green, between 3 and 4 orange, between 4 and 5 red. If anyone can help it would be very appreciated! I’m new to dynamo and sort of new to Revit, and I’ve been teaching myself to get through my thesis but in this aspect I’m a bit stuck…
Thank you for your time
Hello and welcome to the forum!
Have you thought about searching the forum a bit?
Also check out DiRoots Plugin, might already do what you want.
Good luck with your thesis!
Hello!
Yes I have been searching the forum for a few days and came up with some similar problems to mine but no quite enough in order for me to pull something for my work :confused:
I will check out the Pugin, thank you for your help!
King regards
Hey,
To get a hang of things with dynamo try the dynamo primer:
Above posted link provides a simple way of doing it via dynamo.
It will need to be adapted to your parametername and element category. So in essence to your project.
Try to get it going by yourself and if you get stuck somewhere on the way feel free to respond here again.
Here’s an example of how to get started using Python and the bisect library, to assign a color according to a range of values
import sys
import bisect
from bisect import bisect_left, bisect_right
import System
clr.AddReference("System.Numerics")
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def get_color_by_interval(value, interval_values=[], color_values=[]):
    Assigns color based on the input value interval.
    Args:
    value (float): The input value to assign a color to.
    interval_values (List): A list of interval values to determine color assignment.
    color_values (List): A list of color values corresponding to the interval values.
    Returns:
    str: The color assigned to the input value.
    i = bisect_right(interval_values, value)
    return color_values[i-1]
def assign_colors_to_elements(lst_elems, parameterName, interval_values, color_values):
    Assigns colors to elements based on the given parameter value.
    Args:
    lst_elems (List): List of elements to assign colors to.
    parameterName (str): The parameter name to retrieve values from elements.
    Returns:
    List: A list of elements with assigned colors.
    out = []
    for elem in lst_elems:
        para = elem.LookupParameter(parameterName)
        if para is not None:
            paraValue = float(para.AsValueString())
            ds_color = get_color_by_interval(paraValue, interval_values, color_values)
            out.append([elem, paraValue, ds_color])
    return out
toList = lambda x : UnwrapElement(x) if isinstance(x, list) else UnwrapElement([x])
lst_elems = toList(IN[0])
parameterName = IN[1]
interval_values = toList(IN[2])
color_values = toList(IN[3])
OUT = assign_colors_to_elements(lst_elems, parameterName, interval_values, color_values)
i am facing issue in the above code given by c.poupin
can someone share what code is written for colors interval ?
and also explain explain me this how this actually works ?
Thank You
the code use bisect python library, you may need to adapt it (bisect_left? bisect_right? )
here is the doc
Wouldn’t IF statements in a Code Block also work?
(so there is no Python :snake: needed)
