rebarTagCheck.dyn (8.3 KB)
I have this script which gets the element ID of untagged Rebars…so i have to copy the id and select by ID in revit…i tried using overiride projection line color from the rythm pack…and the OOTB overide element color but none of those work.
Hi @ashwinash112,
I had a script which I made to change the color of the Rebar depending upon their diameter. May be you can have a look at this. The graph dynamo version is dynamo 2Rebar Colour.dyn (98.3 KB)
For that u can actually try ’ Color Splasher ’ A free revit Add-onrebarTagCheck.dyn (15.0 KB)
The script doesn’t open… can u post a screenshot
