Hi ppl;
Do you know any other node that i couldget vector of column other than “ToColumnGeometry”. Because in my case this node getting wrong value.
This looks right based on what I am seeing; do you have a small sample data set and .dyn to test with?
Okay it will be shared tomorrow. Since I’m outta office at the moment. Thanks for quick response.![]()
Hi. I’m arincakkin’s friend. I sent you data and .dyn file. I hope if you can help us find out the way to solve it. Everything is quite okay. Just only the last past remain: rotate column with angle.
I do not see any file posted. Please upload to the forum when you have it.
Here are the files.
test_2023_11_15.rvt (5.2 MB)
Create Column_Structure Wall_2023_11_15.dyn (184.9 KB)
here an solution with Python
import sys
import System
# Add references
clr.AddReference('RevitAPI')
# Add references to 'RevitNodes' and 'RevitServices' for Revit-specific functionality
def get_DatasColumns_from_CAD(importinstance, lst_layerName=[]):
datas = [] # Initialize an empty list to store data
# Define vectors for X-axis and Z-axis
vect_X = DS.Vector.XAxis()
vect_axis = DS.Vector.ZAxis()
# Create an Options object for importing geometry
opt = Options()
# Get the geometry of the import instance
geoSet = importinstance.get_Geometry(opt)
# Iterate through the geometry set
for geo in geoSet:
if isinstance(geo, GeometryInstance):
for g in geo.GetInstanceGeometry():
if isinstance(g, DB.PolyLine):
# Get the graphics style and name of the current polyline
gStyle = doc.GetElement(g.GraphicsStyleId)
gstyleName = gStyle.GraphicsStyleCategory.Name
# Check if the layer name is in the specified list
if gstyleName in lst_layerName:
# Create a DesignScript polygon from the polyline
ds_polygon = DS.Polygon.ByPoints([p.ToPoint() for p in g.GetCoordinates()])
# Explode the polygon into a list of DesignScript curves
lst_ds_curves = ds_polygon.Explode()
# Find the longest curve in the list
longest_curve = sorted(lst_ds_curves, key=lambda x: x.Length)[-1]
# Create a DesignScript surface from the perimeter points of the polyline
ds_surface = DS.Surface.ByPerimeterPoints([p.ToPoint() for p in list(g.GetCoordinates())[:-1]])
# Calculate the center point of the surface
pt_ds_center = ds_surface.PointAtParameter(0.5, 0.5)
# Get the direction of the longest curve
vector_direction = longest_curve.Direction
# Determine the clockwise factor based on the cross product with the X-axis
factor_clockwise = 1 if vector_direction.Cross(vect_X).Z < 0 else -1
# Calculate the angle from the X-axis
angle_from_BasisX = vector_direction.AngleWithVector(vect_X) * factor_clockwise
# Append the data to the list
datas.append({
"Layer": gstyleName,
"Geometry": ds_polygon,
"Center": pt_ds_center,
"Direction": vector_direction,
"Angle": angle_from_BasisX,
"longest_curve": longest_curve,
return datas
# Unwrap the import instance and layer name list from the Revit input
importinstance = UnwrapElement(IN[0])
lst_layerName = IN[1]
# Call the function and assign the result to the output variable
OUT = get_DatasColumns_from_CAD(importinstance, lst_layerName)
if you want only vectors ![]()
Thank you so much @c.poupin
I add 2 properties (as key)
WidthColumn and LengthColumn I think you will need it ![]()
import sys
import System
# Add references
opt = Options()
for geo in geoSet:
lst_ds_curves = [curve for curve in ds_polygon.Explode() if curve.Length > 0.001]
# sort curves by length
sort_curves = sorted(lst_ds_curves, key=lambda x: x.Length)
# Find the shortest and longest curve in the list
sortest_curve, longest_curve = sort_curves[0], sort_curves[-1]
ds_surface = DS.Surface.ByPerimeterPoints([p.ToPoint() for p in list(g.GetCoordinates())[:3]])
datas.append({
"WidthColumn" : sortest_curve.Length,
"LengthColumn" : longest_curve.Length,
return datas
