Order of Operations
Hello again :slight_smile:
If you need, I can provide some guidance about the graph.
Thank you so much in advance!
@joaofmoco - Are you getting pop-up errors like this? If so, they may be causing the issues. Either that, or I’m just getting them using a default Structural Framing Type as I don’t have yours :smiley:
I’m not getting any errors. I’m only getting some warnings early in the graph. But they don’t affect the process.
Theoretically I can’t see anything wrong with your use of the PassThrough node if it’s as described above, or in my image below (Note: Nodes look different because I’m in Dynamo 2.13 / Revit 2023).
The PDF set of instructions should never kick-off before you have finished creating the Structural Elements and Setting their parameters.
I didn’t manage to get the graph working as intended though as my set-up (Revit template) etc. is different to yours, but I don’t think this matters in theory.
Any thoughts @jacob.small ?
I’m going to provide my Revit template for you to test the script. Maybe that can help
Template.rvt (3.4 MB)
Using your template @joaofmoco I get the following result - is this what were after?
And that’s inside the PDF?
If so, yes that’s the result we’re after!
Thank you for the massive help :smiley:
Views don’t necessarily regenerate the graphics on the page until the transaction is completed. If you find that PDF exports aren’t showing the final output, a Transaction.End node followed by a Transaction.Start node will usually do the trick.
If things persist, try inserting those after the final modification, and just before PDF export node.
Hello Jacob and thank you for your reply,
I have tried the Transaction nodes before the PDF export and after the final modification. However, it was still producing the same result (PDF export executing first).
Maybe it’s because the Structural Framing node was disconnected. I’m going to try it and see
Hello everyone,
The graph just needed a few tweaks but it’s (finally) running the structural framing before the PDF export. Thank you all for the tips and help :slight_smile:
However, there’s still the issue of the PDF export not working because of Print Range. When I try ā€œSelectā€, it brings up that the printer is not connected. When I try other modes ("Currentā€ and ā€œVisibleā€), it brings up this exception:
ā€œTraceback (most recent call last):
File ā€œā€, line 156, in
File ā€œā€, line 101, in PrintView
Exception: This property is only available when user choose Select of Print Range.ā€
What might be causing this? I know it’s one of the PDF export parameters but I’m not quite sure which one it is. Any suggestions?
I apologize in advance for bothering, I’m new to Dynamo.
The only change to the graph I made was what I originally said above by connecting in the end of the Structural Framing workflow into the PassThrough node :slight_smile:
So, theoretically this should be a good place to start. Beyond that, you may need to also add in the Transaction nodes as Jacob mentioned.
The PDF node itself is from a package, which means it’s been built in a certain way. This error message is stating that it has been coded to only work with the Select option from Print Settings.
Thank you so much! I made it work now :slight_smile:
Awesome! Glad you got it working :raised_hands:
