Orchid - Associate Element Parameter to Family Parameter Multiple Flies
Hello everyone.
I am using Orchid Package trying to Associate the Material Parameter of a Free Form Element to the Material Family Parameter as you see below and… I want to do it in multiple files at once.
When I use it, the node All Elements of Type does not show any element selected but the files selection worked fine.
But, if I substitute the file selection by Current Document it works fine.
I am pretty sure it is something silly I did not understand yet… Any ideas?
Thank you!
Maybe post your query to github? Eric might help you there?
My only thought is that it looks like an instance parameter, can you see if it works with a type parameter?
Cheers,
Mark
You can try this, this worked for me:
You may need to install Rhytm for the collector node.
Best Regards,
