You can obtain the data from a dwg file or groups of dwg files which commands were used, the dates, when the file was created, the history of the
Hi @DJack,
Your post is a little unclear. Can you try again?
What I want is to know which command was used in an autocad file and in which
Are you looking for the history of each command used in a DWG since it was first created until the current time?
Yes, that is what I wish I could do
