Opensource codes API
As we know dynamo is opensource. I want to see what the node Surface.ByLoft in dynamo is using from the Revit API (c#). How and where can i find the opensource code?
Thanks!
Surface by loft doesn’t call the Revit API - it’s available in Dynamo core.
The code behind all the nodes is available in the relevant GitHub pages, which are available here:
Note that not all aspects of the code are open source, some aspects such as the geometry engine are called from other libraries for which the code is closed source.
Thanks for reply. I already searched in github but couldn’t find it. But now i know that it isn’t there.
