Dynamo node
Hello every one
I want to study the methods used to create original node library in dynamo.
where can I find the programming script for study?
Thank a lot
The builtin nodes are closed source, you cannot study them. Some 3rd party libraries are open source, e.g:
Or find sources with topics on github:
Below is the open sourced code for dynamo, I would suggest you watch out with what you do because some of the parts are not open sourced as per license note within dynamo.
Source code for dynamo GitHub - DynamoDS/Dynamo: Open Source Graphical Programming for Design
Source code for Dynamo for revit: GitHub - DynamoDS/DynamoRevit: Dynamo Libraries for Revit
thanks a lot for the information.
