OpenMEP Package Feedback Thread
Hi, I installed but not seen on Dynamo add-on list.
I using two version of Revit could you please advise me thanks.
Revit 2020.1 & Dynamo Revit 2.2.1.5291
Revit 2022 & Dynamo Revit 2.10.1.4002
Hi @pe_simon
  • For Revit 2020, the support version of Dynamo Revit is 2.3
  • For Revit 2022, the supprot version of Dynamo Revit is 2.12
    In case you need to use for older version like problem you are facing , you need to do manual way
    1. Copy Dynamo Sanbox to target folder support e.g :
C:\Users\<username>\AppData\Roaming\Dynamo\Dynamo Core\2.16\packages\OpenMEP
    1. Copy Dynamo Revit package support to folder support :
C:\Users\<username>\AppData\Roaming\Dynamo\Dynamo Revit\2.16\packages\OpenMEP
Regard
Hi. Any video for the procedure? thanks.
    • I download Dynamo Sanbox (DynamoCoreRuntime3.4.0) and extracted to the C:\Users\XXXX\AppData\Roaming\Dynamo\Dynamo Revit\2.16\packages\OpenMEP
    • But Cannot find the Dynamo Revit package support for download.
Hi @pe_simon , you need to download msi Match with Revit not in sandbox because your target is keep using inside revit. I will explain what is included in Revit msi installation from release:
  • Sandbox : Use Dynamo independent without Revit or Autocad
  • Revit : Can use with Sandbox and Revit
  • Civil : Can use with Sandbox and Civil3D
unfortunately, I don’t have any video tutorials to help you step by step , but I hope what I’m explained is make sense to you !
Can’t install OpenMEP for Revit 2025.4
I installed the latest version (OpenMEPRevit-2.0.24.2811556.msi) of OpenMEP. However, the package does not appear in the Dynamo installed packages or Add-Ons list.
I am using DYNAMO v.3.3.0 and Revit 2025.4 (25.4.0.32).
Hi @mtanyer, Sorry for late reply because new year time vacation, I will update as soon as posible and information to you. Thank you .
What Is News: 2.0.25.62550
  • Update Revit 2025.4
  • Add Support Nested Check Element
Hi, is OpenMEP available for Revit 2026?
Hi Tim. Unfortunately the project is no more maintenance right now. It’s is overload for developer to maintenance in free time support .
Regards
Is the documentation avaiable for this package? Thanks!
Hi @rojasdanielandres , please feel free to access full document here : Namespace OpenMEPRevit.Document | Open MEP
Hi Tim,
Sorry for my busy time, but I just want keep you an update, the version support Revit 2026 just released today. Release 3.0.26.83157 · chuongmep/OpenMEP · GitHub
Regards .
Bump Release 3.0.26.241258
What Is News:
  • Add Revit/Autocad 2027 (R27) Support
