OpenMEP Package Feedback Thread
New version supported Travelling salesman problem Find Shortest Route
Point.FindShortestRoute
New version : 2.0.23.1071410
New Version : 2.0.23.145159
New Version : 2.0.23.148151
Revit_ZDaDEFbd4K
any change of making a longest path node for graphs?
Look into topologic, which added this recently to their code i believe.
For this node, we allow return all path can have of graph and all distance of them, you can easy get shortest or longest of path Class Path | Open MEP
New Version : 2.0.23.1561525. Now we had allowed you can get data of AutoCAD from anywhere with Dynamo Revit or Dynamo Sandbox.
New Version : 2.0.23.1571441 Supported :
  • Supported Installer Package on Dynamo Civil3D
  • Supported Get Dynamic Block Name From Com Object
  • Improve Documentation.
Hello
I have a problem that I can’t solve
I don’t know if you can help me with this node for revit 2023
thank you
Cesar
Hi @cascencio , thank you for use OpenMEP, input systemType and pipeType require Type input, but you has input name of this, you can try with example at here : Class Pipe | Open MEP
New Version : 2.0.23.2181218
New version in 2.0.23.2331336 released :kissing_heart:
What is news : Add more power full to work with Bounding Box
  • Boundingbox.IsSimilar
  • Boundingbox.Scale
  • Boundingbox.Divide
  • Boundingbox.Visualize
  • Boundingbox.Area
  • Boundingbox.Volume
  • Boundingbox.ByBoundingBoxs
  • Boundingbox.Corners
  • Boundingbox.Center
Demo Preview :
explorer_DAjsKIWxYK
BoundingBox.ByBoundingBoxs
See more detail document : Class BoundingBox | Open MEP
What is New in version Latest
What is news in Latest:
  • Fix Config Release Version On Branch
  • Fix Build Config Version .NET
  • Update Nuke Release Description
  • Improve R24
  • Fix Api Missing With Lower Version
  • Add Support Get Id Cloud Project Model
  • Add Support Get Id Cloud Model
  • Fix Null Ref
  • Add More Function Document
  • Add Pickorderlinkelements
    See What is new in previous release: 2.0.23.240342 Release
What is news in latest version :
  • Upgrade Support Dynamo Revit 2025
  • Upgrade Support Cad 25
  • Upgrade Support Dynamo Civil 3D 2025
  • Upgrade Support Dynamo Sandbox 3.0
  • Support Coordinate Convert
  • Fix Get Relattive Path
  • Migrate Cad COM Interop
  • Add Filefromrelativepath
New update supported easy to get Location Gridline belong to element for tagging :slight_smile:
Download Latest Release: Click To Download
If you don’t have one currently, nearest grid in both directions is very handy also. That or including a dictionary of distances to those grids so the user can use them to inform if left/right and top/bottom are closer than one another.
Thank you for your feedback, I believe it useful, will consider relevant to some node support
Follow with your idea to extend function support for gridline, What Is News:
  • Add Getclosestgridline
  • Extend Getlocationgridline
  • Fixed issue releate to break gridline
