Are there any custom nodes in Dynamo that will make it possible to open/close worksets in the current model?
I don’t know if this is possible via the API directly at this time - the only method I have seen requires a closed model to start with. You could look into a heavy work-around, but there will be a LOT of limitations around it’s use. So before you start can you outline ‘why’ as if you’ll hit a blocker once implemented there won’t be much use in spending any time on the task.
