Open document in background
The node for opening Revit document in the background seems to be no longer working. Is there any alternative preferably an OOTB method.
Are you opposed to python? Orchid package also has a lot of document handling nodes, but they work just a little different than typical nodes do so you have to modify your approach sometimes.
Hi @theshysnail,
You probably need to update the Rhythm package. The warning is gone now.
I think @john_pierson changed his mind about this node.
Hi @theshysnail maybe you can install a old version of the great Rhythm packages, for example the 2019.3.14 version.
Cheers
:see_no_evil: I did change my mind about it.
for now:sweat_smile:
@theshysnail even with that warning the node is still functional though.
