Hi, I’m working with dynamo for auto rebar modeling.
The picture explain what i did. (gave stirrup rebar’s line and stirrup rebar’s height to geometry.translate node.)
What I want to do is get rebar’s lines at each height I gave.
In other node (which i made in same project) works fine. they gave me rebar’s lines at each height, but only this node donot return correct thing.
I guess the answer is adjust lacing, so I already did every case of lacing but didnot work fine.
thank you for your help
