Hi all,
I am new to the dynamo and was wondering how to offset points generated from the solid.centroid in a perpendicular way from the surface of the elements?
Hi all,
Hi jpmuccini welcome to the forum, here is with the solids centroid
Thanks for looking at that for me sovitek
I set up the same script here but no luck, would you be able to tell me what I did wrong?
Could you share the file…so i will take a look
Sure, see attached
Offset points.dyn (12.0 KB)
Sorry i mean the Revit file or just a file with the wall geometry
I am having trouble in uploading the Revit file as it exceed the maximum size permitted. But the project is just a basic four walls project.
Alright if you want you could use filetransfer, becourse here is just works fine
Are your walls build on a mass ?
link below to revit file. Thanks again!
It worked! Thanks, much appreciated, sovitek.
Great, apparently something wrong with the wall orientation node from Clockwork…but strange becourse here is just works fine
That’s weird, could it be the case that I need to download the latest clockwork package?
