Hi Kulkul.
By all means. I’m not sure how helpful it is, as its really just a surface, from which I extract the edge curves. I have faked a codeblock with some dummy code to illustrate what I would like to do.
Thank you. I like the concept. However, I need the offset distance to be constant on the 3D surface, whereas in this workflow it is only constant in the projection plane.
