So the basis for the question is;
I’ve been working on a definition to create a building mass based on a few inputs. Height, Location of Elevator Core, Number of Units, typical room dimensions, stair tower location, and driven by a single datum line from revit. It works great with one ongoing issue. Direction of offset or thickening of a surface. It appears to be driven by two items(kind of the same) The direction the line is drawn in revit, and the convex or concave shape of a curve.
In test cases I have been able to function by added varies ‘-1*x’ to flip direction and ‘reverse curve’ node. However I feel like there is a better solution to controlling offset / thickness directions, mostly because when i test a line in the opposite direction i must track down which items to flip - If possible i would insert a simple toggle to flip everything…
My question is what setups have been used successfully to control the offset or curves / direction of geometry creation more consistently and globally?
