Offset Alignment Parameters
Hello all,
I have a requirement where I need to automate creation of offset alignment widenings and change the parameters as well. For example, add transitions other than linear for widenings.
I have created the widenings as desired successfully, however, I am unable to find a way to change the transition type to curve-linear-curve. Is there a way to do it in dynamo? I am doing it for around 30+ offset alignments at a go and hence do not want ot go into the manual methods.
Could someone point me in the correct direction please?
Have you tried the Arkance package?
@patrick.ericson the widenings have been created using the Arkance package itself. I wanted to further modify the widening parameters.
If I remember well, there is no option to set the type. It is not in the API.
Alright. It seems like will have to create new alignments altogether at those locations.
