import sys
import math
Rectangle = IN[0]
lst_offset = IN[1]
lst_1 = []
lst_2 = []
#Offset in positive direction
"""for d in lst_offset:
lst_1.append(Rectangle.Offset(d))"""
#Offset in negative direction
a = -d
lst_2.append(Rectangle.Offset(a))
OUT = lst_2
A rectangle 16 units long and wide can only be offset inwards by 8-1/infinity units before it collapses into a point, as you are offsetting the left and right 1 unit towards each other concurrently, so offsetting by 1 gives you dimensions of 14, by two 12, by four 8, by seven 2, and offsetting by 8 gives zero which is no longer a valid polycurve.
Adjust your starting rectangle to something larger than 20 units and check the code again, or reduce to offset to maximum (1/2 of the width -1/infinity). You could also add some error handling to remove any values greater than or equal to 1/2 of the width or length.
Also seeing the warning message can help with resolving/diagnosing these types of issues in the future.
