You’d still want to keep that when it comes to the selection part probably using select all of type mode. You’re probably familiar with this post doing same select all autocad points Cogo points from AutoCAD points & OD - #2 by mzjensen
Yeah that add new types node is a bit tricky, I’ve learned about it’s quirks through AU classes and other youtubes I think, and is mentioned in the form from time to time.
