Hi all. What am I missing here? I am trying to get all polylines with the All Objects of Type node in my live document and the problem that I am facing is that I have to save the workspace and reopen in order for the Object Types node to feed anything to the node downstream. Is this behaviour as intended?
Often I want to build myself a quick graph to extract some type of data from my dwg that I won’t use again, but this defeats the whole ‘quick’ intention.
Currently running C3D 2024.
Hi @s.proch,
This node had a bug where it would always return null after placing it in the graph with the run mode set to ‘Automatic’. It was fixed in Civil 3D 2025.
The workaround is to make sure that the run mode is set to ‘Manual’ when first placing the node and selecting a value. After that, it should run in ‘Automatic’ mode without issue.
Thanks a lot!
