Hi @BIM_Croatia
Well! You can get the Text Objects Contents without converting MText:
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.EditorInput import *
# Import references from Civil3D
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
tv = []
errorReport = None
for oid in btr:
bl = t.GetObject(oid, OpenMode.ForRead)
try:
if isinstance(bl, DBText):
tv.append(bl.TextString)
# Catch and report Exception...
except:
import traceback
t.Commit()
if errorReport == None:
OUT = tv#Text Values
OUT = errorReport
