Hello, viewing these two, differently created Nurbscurves with the same degree in geometry view shows that they are exactly the same, overlapping each other, however, when i extract their curve lengths they are different by a factor of 3! What is going on here? Why arent they the same? What is this trying to tell me?
Can you test the distance between the two curves with a geometry.distance to node?
Might be a scale issue… let’s try this point at parameter 0 for both, then distance between those.
My gut says your curve is broken and not on top of the other curve, but since we can’t see the start points for each I don’t know.
Also try pulling just the points from the lists which make these two curves, then comparing the distance between those.
Try making a Nurbs Curve from those point lists and check those lengths.
What is your geometry scale setting?
you mean this?
I did. Thought you might be on extra large. I can’t reproduce this from the basics geometries (recreating the points from X Y and Z values you showed), so something somewhere in your graph has corrupted your data. Try using it on a smaller project sample size and see where that gets you.
