Number objects in Revit
I’d like to number Objects (windows) with Dynamo.
I use “List.GroupByKey” because I want to number left’s windows and right’s windows separatedly.
Difficulty : I need to number from 0 to xx, next to the red and ugly arrow
Someone can help me?
thank you
Sami
Some nodes which may be of use here:
BoundingBox.Contains
List.GroupByKey
Geometry.DistanceTo
List.SortByKey
Range
That may fall apart if you have a more elaborate façade, but you’re only showing an L on each side so currently it works.
You can also use a selection by curve method if you want to just ‘trace over’ the walls with a line in plan. Look into ‘renumber by spline’ on the forum for that - there are some good examples using piles.
Thank you Jacob for your help.
I take a look of old message about “renumber by spline”
i let you know
ty
i try some dynamo node about Renumber by spline
but i have “Avertissements”
Can someone explain me what does it mean?
