I’m very new to Dynamo and trying to create a renumber script for windows with a pre fix.
I’d like to select all windows in the Revit project and get an output that would look like this: W-1, W-2.
I think I got the prefix part to work, I just need to find a way to override the current mark and renumber them.
You will want to count the list of elements, then you can create a number range from that value starting from 1, then use to combine with your prefix to write to the parameter. Hope this helps!
