Not able to print sheet set as a combined PDF
Hi All
I would like to print a sheet set and would like to obtain otput as combined pdf.
Please refer below attach image for error and along with dynamo script.
Batch Print.dyn (24.5 KB)
Thanks in advance
Ravi
could you show the previews below the nodes so we can see what data is being passed?
Hi @Garbage_Collector
Please take a look at the attach image for taking look for the previews of the nodes.
Please help me to solve the issue
Thanks in advance
Ravi
Hi @raviYPR7K probably a flatten could help here
Hi Ravi,
What are we trying to achieve with the script? Isn’t there already option to print combined pdf in built with Revit?
Hi @Sujan
Yes It is available in Revit , but we can only print one sheet set at a time, I would like to achieve to print multiple sheet sets and output of each sheet sets as combined pdf seperatly.
I am looking forward your suggestion
Regards
Ravi
Hi @sovitek
Thanks for suggestion
I am getting same error , please take a look at below attach image
Please help me to solve this issue
Regards
Ravi
Hi genius loci have some great nodes for print as well and a node for merge pdf…probably more stable,its very long time i have use these print nodes from archilab, and if i remember right it isnt so stable …
Hey Ravi,
In the error it says it is expecting “string” but getting “List”. Try changing the List Level here
Hi @Sujan
Thanks for suggestion , Script is able to print each sheet seperatly , but not getting as combined pdf.
Please refer attach script and image
Help me to resolve this issue
Regards
Ravi
Something like this should help. Make sure that the number of filepath is same as Viewset
@Sujan is right - You can’t name a combined PDF the name of all the sheets, of if you do it will do (Number of Sheets)² pages across Number of Sheets files.
The node is quite out of date - use Export PDF from Genius Loci if you are on Revit 2022+
Hi
I tried it but print only 1st sheet.
Hi
Thanks , I tried with Export PDF node and it work me.
Please refer the script image
