I self-taught Dynamo and i have never read
the Dynamo Primer.
I just set a goal and then looked here for topics
about what i wanted to make. And YouTube.
I have a small Powerpoint where i try to explain
things like; integer, double, string, instance, type and such.
I am willing to share it
(you only need to translate it from Dutch to English).
It might have some small mistakes in it and it is far from perfect, but was still pretty useful teaching some of my collegues.
Better step for me would be to provide some of the recordings from previously delivered trainings (similar to the Dynamo Office Hours, but done for internal users at my employer… who also makes the thing so I am admittedly an outlier).
Drip the education out one recording at a time, with the 4-6 sessions spread out over the time that I have to give (say a 15 minute chat each Tuesday at lunch).
There’s a ‘try it’ exercise at the end of each which I’d review if they did it, or answer questions they might have. At review I’d open the next video and progress to the output. They don’t have time to watch the video or do the exercise then I don’t have time to each them as they won’t learn with me in person either. Happens twice and we’re done.
If I have 180 minutes (3 hours) I’m going to spare with them in person (say during 3 lunch breaks or 3 evenings right after work) then I’m doing a full workshop and calling it quits. Something like:
UI tour (15)
Library navigation (10)
Useful extensions including graph node manager, documentation browser, and autodesk assistant (15)
data types (10)
lists (5)
lacing (10)
levels (10)
Follow along demo (10)
Session one ends - 75 minutes
geometry types (5)
Geometry inheritance (5)
geometry modificaiton (10)
Geometry display (10)
data utilization (10)
Follow along demo (15)
Session two ends - 55 minutes
Revit connection (5)
Read Revit data (5)
Writing Revit data (5)
Session three ends - 30 minutes
I’m giving them Monday morning and Wednesday morning to have a look… But I don’t have that time myself to spare to show them.
I’ve some old training stuff - but it’s rather out of date.
Any specific videos you’d recommend I tell them to watch?
I’d like to set some tasks.. but totally out of touch with what’s realistic in that timeframe.
I think the best way to learn Dynamo is to take a real-world problem, then learn how Dynamo how can be used to address it
I think (randomly) going through the primer may have some value- but it’s a bit like saying “I have this hammer- what can I use it for ?”
Hi @Alien i have always go with get/set parameter first very simple instance/type and still very powerfull, and then import/export value from Excel and here explain the different data types as most users work in revit and want use it for revit, and if they are still interested ;)…go to geometry and all the other stuff we can do…but for all learning they have to be interested in it and basic all learning in the end is a personel thing if not, they will never learn it…so many times its about to do it funny and present the right way…just my 2 cents
I love that we’re in a space with a wide range of opinions, even if some of them I disagree with.
Not ensuring users learn the basics is how you get scaled use of the worst practices across the firm.
In air traffic control this is how you get pilots who can’t figure out how to use the radio never mind land the plane. Remember the pilots goal isn’t to fly, but to get to another location so don’t get made if they get frustrated and leave the plane on the runway.
In BIM this results in 1000’s of parameters named Color in a model so no one can ever set the right one. The BIM modelers goal is to get a deadline out the door, parameters weren’t part of that, so it’s not their problem - the BIM manager can deal with it or we can just let it slow down everyone else’s work.
And in Dynamo this results in one Excel.ReadData node followed by 10 different List.GetItemAtIndex nodes connected into 10 different Element.SetParameterValueByName nodes, and a graph that runs out of memory and has to start writing to the scratch disc at the second List.GetItemAtIndex node. This inevitably leads to dissatisfied users.
Teaching the basics needs to happen, no matter the thing you want people to use. Many of the “old hat” users forget this need, as we learned a lot of the basics for other automation needs (i.e. I am 90% certain you knew the difference between a string and a double before you ever started Dynamo @Andrew_Hannell).
My experience as Noob whose never programmed before, but I’ve been able to pull things together well enough to do what I need:
Finding small problems to try to solve instead of starting on big ones, especially ones that are doing analysis instead of model changes. I feel like so much of the learning curve is poking around to find what nodes/functions are available and having an analysis kind of problem is helpful to learn the nodes but at least the actual data content is already and in the right format for you to find/use.
IF you’re “old hat” and have experience with coding already. Also context and being a native English speak helps. There is no Dutch word for string really for example .
This when i started with Dynamo. That being said. It would have helped me a lot if there was someone who could explain things in person to me when i got stuck at that time.
My starting point for being trained is not my colleague’s starting point is not my boss’.
I think real-world examples have a place, notably for seeding interest and potential, but training should be done with rigour suitable to the current understanding and skill level. Unfortunately, this means having oversight over the process unless you plan to apply course correction after finding out how they spent several hours trying to track down Element.Parameters in the search window.
My employer has given me more than my fair share of time on the forum without requesting me to back of, so I am sure some of what I write gets put into Autodesk Assistant at some point… hopefully this means I’ll have a better chance at getting Hal to open the pod bay doors.
Seriously though - this isn’t a technology thing but a people one. That makes knowing the individual the first step in ensuring things work out. If you’re working with someone who learns best by pulling the buttons and seeing what happens, then go that route! My experience is those users have usually already taught themselves by the time you get asked though. That means the vast majority are the people who need at least a little bit of understanding before they get started. AI may change that to some extent it should be able to get a good picture about how you learn pretty quickly from what you do, and the LLMs are quite good at explaining the underlaying tech. However this will also will bring new challenges that it won’t be able to train people up on, and in topics where no one has a ‘here is how to do it’ experience.
As such the leaders of the computational design communities (of which there are 7 or 8 in this thread already) are going to have to learn a whole new set of processes as we welcome the next generations of users. The only thing I know is this is going to be a very interesting time for us all.
Yes, this is VERY difficult for many. The further removed from English the language is the harder it becomes.
One thing that can help is the combination of AI assistance and the documentation. Asking assistant to explain lacing to you gets pretty good results if memory serves. Bonus point in that you can ask for that explanation in the language if your choice. Of course that is all predicated on you being in the 2027 product line with an Autodesk Assistant connected Dynamo build… But I am confident the team will have some cool stuff to reduce that issue in the near term.
The Dynamo Office Hours series would be good. It’s old for sure, but quite powerful. A remastering might be worthwhile but I think it’d be premature based on the shifting landscape we are currently in.
If you don’t have good videos to point people to, I recommend using the introduction for this user as the chance to get them. Record the sessions you have and see what you can stick together. But the one thing that recordings and workbooks and canned content can’t do is address those individual learning styles. That’s always the easy way to effective learning and it requires time and insight from both the student and the teacher.
I agree that AI can be very helpful, but i think it is very value people are able to problem solve without the use of AI. AI might not always be available. You might ran out of tokens or the serivce is down.
Also AI can put you on the wrong track if you ask the wrong questions / ‘bad’ prompting.
But then you have to translate it back and some stuff might get Lost in Translation.
So true.
@Alien sparked a nice little ‘debate’ (in a good way ).
