Node for getting property of Civil Objects
Hi, is there any node for getting this object property? It seems I can’t access it using Object.PropertySets. I’m using Civil 3D 2025.1, thank you
I couldn’t find a node either, however, this might help you get information from the object using the API:
import sys
import traceback
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
# prepare output
res = []
# set input
selection = IN[0]
with adoc.LockDocument():
    with adoc.Database as db:
            try:
                for dynobj in selection:
                    obj = t.GetObject(dynobj.InternalObjectId, OpenMode.ForRead)
                    if type(obj) == MaterialSection:
                        # properties see: https://help.autodesk.com/view/CIV3D/2023/ENU/?guid=acf87e4e-4beb-6270-7e56-6e25cfa0948f
                        # or res.append(dir(obj)) for full list of the cals props / methods
                        res.append({"Area": obj.Area,"Station": obj.Station})
                        res.append(type(obj))
            except:
                err = traceback.format_exc
                res.append(err)
            pass
OUT = res
Apparently the Area property is inherited and not the value you might expect. You may add:
                        sectionpts = obj.SectionPoints
                        pts = Point3dCollection()
                        for spt in sectionpts:
                            pts.Add(spt.Location)
                        poly = Polyline3d(Poly3dType.SimplePoly,pts,True)
                        res.append(poly.Area)
for every MaterialSection to obtain the area… This gives me the same values as in the properties window.
That’s a great question! Before 2025.1 with all the new nodes dropped, you could do something like this, using nodes from the Civil3d Toolkit. This would list all directly available parameters.
As of now, the Civil3d Toolkit hasn’t updated and I’m not sure it will because I don’t think Autodesk will supply two different packages? Here’s a post descriping the status quo.
I hope a dedicated node will be incorperated in the future, until then you might have to use python as @geert.drijfhout provided.
it works, thank you
yes, I also used Civil3D Toolkit before. I hope it will get updated soon. Thank you for the response
Just to point out: I did not manage to get the Area from the Civil3dToolkit GetParameters Node, probably scince it is not a class property of the Material Section.
