Autocad Solid Material
In dynamo for Civil3d is that possible to acces the material propreties of an object (autocad solid)? I’m able to get the object color and layer but not the material.
thanks for your help
Hi @francois.picard
I haven’t find any nodes to get material but you can get with python:
import sys
import math
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('Civil3DNodes')
from Autodesk.Civil.DynamoNodes import Profile
from Autodesk.DesignScript.Geometry import Point, Polygon
editor = adoc.Editor
with adoc.LockDocument():
	with adoc.Database as db:
			bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
			btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
			mt = []
			errorReport = None
			for oid in btr:
				bl = t.GetObject(oid, OpenMode.ForRead)
				try:
					if isinstance(bl, Solid3d):
						mt.append(bl.Material)
				# Catch and report Exception...
				except:
					import traceback
					errorReport = traceback.format_exc()
			t.Commit()
if errorReport == None:
	OUT = mt#Material
	OUT = errorReport
I’m adding it to the Civil 3D Toolkit in the next release
Thanks @Kulkul!!
And good idea @Paolo_Emilio_Serra1
