Hi everyone! I’m very new to Dynamo and days ago I tried to do an excercise about creating a lake model according to the existing topography .
I used the function “create in-place mass” in revit as a quick solution and in the script I used the node “geometry split” to cut the mass that I created and “FamilyInstance.ByGeometry” of spring nodes to export from Dynamo in revit the upper part of the mass but in Revit I don’t find anything.
I tested this script also on anther PC with exactly the same file Dinamo&Revit and it worked. Both my PC and this one have the same version of Dynamo 2.3.
Did somebody went through this situation before could gently responde my doubt?
Thx in advace!
PS: I tried also manual mode it didn’t work.
