'No method matches given arguments for OnExist' error
Dear Dynamo Experts,
I have been using Dynamo script with IronPython2 node on Revit 2022, without issues for the last 2 years.
This week, I wanted to use the same Dynamo script on Revit 2025.
As Revit 2025 is now using CPython3, I immediately got the following error:
TypeError: No method matches given arguments for OnExist (<class 'Autodesk.Revit.DB'Transaction'>,<class type>, <class TypeError>, <class traceback>) ['File "<string>", line 973, in <module>\n']
The error is raised when on line: t.Commit().
Here is an excerpt of the code:
from System import Array
import System
import time
import math
import sys
clr.AddReference("System.Drawing")
clr.AddReference("System.Windows.Forms")
import System.Windows.Forms
import System.Drawing
import csv
try:
    # dynamo dlls
    import Revit.Elements
    clr.AddReference('DSCoreNodes')
    import DSCore
    from DSCore import *
    # revit dlls
    clr.AddReference('RevitAPI')
    from Autodesk.Revit.UI.Selection import *
except Exception as e:
    pass
element = UnwrapElement(IN[0])
move_vec = DB.XYZ(0,0,1)
with DB.Transaction(doc) as t:
    t.Start('transaction 1')
    el_id_L = System.Collections.Generic.List[DB.ElementId]([element.Id])
    DB.ElementTransformUtils.MoveElements(doc, el_id_L, move_vec)
    t.Commit()  # THIS LINE RAISES THE UPPER ERROR
Is this typical CPython3 vs IronPython2 error related with transactions?
I looked at Python2-to-Python3 document, but couldn’t find anything about transactions.
Does anyone have any suggestion how to solve this error?
I am quite desperate at the moment.
When I try to use the internal “Convert script to Python3” functionality inside the Python3 node - the Dynamo simply gets blocks, and crashes. The python code is longer then upper excerpt, but still the error happens on such MoveElements transaction.
I would be grateful for any kind of help.
Thank you in advance.
Try removing the With statement - it isn’t doing you any favors here, and they can be problematic in CPython.
For this scope I don’t think you even need to declare the specific transaction - give the default transaction manager method a shot and see if that works. Then move into building a transaction as you would any other variable if needed - no significant speed impact otherwise.
That said, the put of the box node Element.MoveByVector will likely outperform this by a wide margin.
Hi @jacob.small ,
Thank you very much for the reply!
So the transaction would look like this?
t = DB.Transaction(doc)  # 'with' removed
What is the default transaction manager method?
The code is slightly larger then presented here. That’s why I have to use python node, instead of Element.MoveByVector.
Looks like it, yes. Does that fail?
See here: dynamoPython/pythonTemplates/RevitPythontemplateFile at 6e3c7f4e2a3af90cd77cc4f3fa2fbccc5070e878 · Amoursol/dynamoPython · GitHub
Slightly indicates ‘moving the element and then starting the Python’ is a valid option, but I get that not everything is as simple as presented and appreciate the ‘here is a simple use case’ nature of the post. :slight_smile:
Both methods worked! Thank you very much for the help @jacob.small .
“with” in IronPython defined a scope at the end of which the “DB.Transaction” object is disposed.
It is sad that in PythonNET, there is no such thing.
Thank you once again for the help Jason!
