Question about the project method in Revit API
I tried to convert my old Dynamo scripts to Python scripts and failed at using the Project Method to get the closest points by projecting a list of points to a curve. Please see my error message and script below and let me know where I did wrong. Thanks a lot!
error message:
Warning: TypeError : No method matches given arguments for Project: (<class ‘Autodesk.Revit.DB.XYZ’>) [’ File “”, line 29, in \n’]
script
clr.AddReference('RevitAPI')
import System,Revit
# collect inputs into center point list
if not isinstance(IN[0], list):
    centerPtLst= UnwrapElement([IN[0]])
    centerPtLst = UnwrapElement(IN[0])
# collect input curve
curve = UnwrapElement(IN[1])
# closest point
closestPtLst = []
for pt in centerPtLst:
    closestPt = curve.Project(pt.ToXyz())
    closestPtLst.append(closestPt)
OUT = closestPtLst
You have to convert the curve also to API type.
Deniz,
Thank you so much! Here is the corrected script in case anyone else interested.
    # curve convert to Dyanmo Type
    curveGeoobj = curve.ToRevitType()
    closestPt = curveGeoobj.Project(pt.ToXyz()).XYZPoint
