See my python script below for setting pressure pipes to a reference surface in Civil 3D. I think I am close with this script, I just can’t figure out how to handle the PointNotOnEntity exception without the script stopping. I have tried try, except blocks, but that doesn’t seem to do the trick. I ran into an issue with something similar for alignments, but the alignments had a specific method that allows for accepting out of bounds values.
Any help in handling these exception and keeping the script running would be much appreciated.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
pressure_pipes = IN[0]
primary_surface = IN[1]
secondary_surface = IN[2]
editor = adoc.Editor
debug = []
# Function to get elevation at a given point on the surface
def get_elevation_at_point(surface, point):
try:
elevation = surface.FindElevationAtXY(point.X, point.Y)
return elevation
except Exception as e:
# Catch all exceptions and log them, allowing the script to continue
debug.append(f"Error at point ({point.X}, {point.Y}): {str(e)}")
return None
def set_pressure_pipe_surface(pipes, primary, secondary):
"""Set alignment reference for each pressure pipe if applicable."""
with adoc.LockDocument():
with adoc.Database.TransactionManager.StartTransaction() as t:
primary = t.GetObject(primary.InternalObjectId, OpenMode.ForRead)
secondary = t.GetObject(secondary.InternalObjectId, OpenMode.ForRead)
for pipe in pipes:
try:
pipe = t.GetObject(pipe.ObjectId, OpenMode.ForWrite)
start = pipe.StartPoint
end = pipe.EndPoint
start_elev = get_elevation_at_point(primary, start)
if start_elev:
end_elev = get_elevation_at_point(primary, end)
if end_elev:
pipe.ReferenceSurfaceId = primary.ObjectId
start_elev = get_elevation_at_point(secondary, start)
if start_elev:
end_elev = get_elevation_at_point(secondary, end)
if end_elev:
pipe.ReferenceSurfaceId = secondary.ObjectId
if not start_elev:
debug.append(f"No surface found for pipe {pipe.Name}")
# Log any errors that occur while processing each pipe
debug.append(f"Error processing pipe {pipe.Name}: {str(e)}")
t.Commit()
return primary
# Execute the function
output = set_pressure_pipe_surface(pressure_pipes, primary_surface, secondary_surface)
OUT = output
Best to use the preformatted text option when sharing code. Edited to help those who might want to copy/edit more readily.
On mobile so I can’t get the desktop view, but this screenshot should help you find what you need (red than blue).
It’s best practice to only open objects when you modify them, also is the pipe/primary a Dynamo object or a C3D object? maybe use InternalObjectId
. Add a continue
after updating the pipe
pipe = t.GetObject(pipe.InternalObjectId, OpenMode.ForRead)
if end_elev:
pipe.UpgradeOpen()
continue # Go to next pipe as no need to process further
You could simplify the logic as you are not using the output of the get_elevation_at_point
function and rather than having multiple try statements - if this throws an exception it can be captured by the main function
def pipe_on_surface(surface, pipe):
"""Check if pipe is aligned to the surface xy coordinate space"""
return all(
for point in [pipe.StartPoint, pipe.EndPoint]
Edit: This will return false if both elevations are zero
Thank you for the help. I am new around here obviously.
I tried implementing these changes, but I am still running into the same exception that is stopping the rest of my code from running. Any other suggestions, or maybe they were implemented incorrectly? I have uploaded the whole script and the revised python code.
I also made a small change to how I am getting the surfaces since I have been running into an issue with the Autodesk package surface selection node. The surfaces and the pipes should both be DatabaseServices objects.
Set Refence Surface (24.08.21).dyn (19.4 KB)
import sys
primary_surface_name = IN[1]
secondary_surface_name = IN[2]
debug = []
# Function to find the TinSurface by name
def find_surface_by_name(surface_name, t):
try:
civil_db = CivilApplication.ActiveDocument
surfaces = civil_db.GetSurfaceIds()
for surface_id in surfaces:
surface_obj = t.GetObject(surface_id, OpenMode.ForRead)
if surface_obj.Name == surface_name:
return surface_obj
return None
debug.append(f"Error finding surface by name: {str(e)}")
return None
try:
return all(
surface.FindElevationAtXY(point.X, point.Y) is not None
debug.append(f"Error checking pipe alignment: {str(e)}")
return False
def set_pressure_pipe_surface(pipes, primary_name, secondary_name):
primary = find_surface_by_name(primary_name, t)
secondary = find_surface_by_name(secondary_name, t)
for pipe in pipes:
try:
pipe = t.GetObject(pipe.ObjectId, OpenMode.ForRead)
if primary and pipe_on_surface(primary, pipe):
pipe.UpgradeOpen() # Needed to modify the pipe
continue
elif secondary and pipe_on_surface(secondary, pipe):
continue
debug.append(f"No valid surface found for pipe {pipe.Name}")
t.Commit()
return None
output = set_pressure_pipe_surface(pressure_pipes, primary_surface_name, secondary_surface_name)
OUT = output
property is incorrect - it is pipe.RefSurfaceId
see API docs here
Hey Mike, thank you for the help. I believe it should be ReferenceSurfaceId since this is for pressure pipes. I apologize if I didn’t make that clear. I was trying to keep the function variables shorter to just pipes. You can see that API reference Here
Your link was for a Civil 3D part
object (the parent of a pipe
object) which also uses the RefSurfaceId
property
The link for pressure pipes is here which does use ReferenceSurfaceId
If the code is still throwing exceptions I would try the following
- Limit the use of
try... except
to code you know will throw an exception
- Use above in conjunction with the python
traceback
library which can get more useful information from inside transactions
- Unwrap the functions unless they are being used more than once and work with one transaction around the code
- Work back by commenting out lines until the code works
- If you are not using an IDE use that to help format the code and pick up type errors
- Be persistent. C3D can be a fussy beast
Some example code to build ObjectId
dictionaries of various database objects - you can then pull the id by using the name using dict.get()
method as it returns None
if it fails
clr.AddReference("AcDbMgd")
clr.AddReference("AeccDbMgd")
def build_dict(id_collection):
return {id.GetObject(OpenMode.ForRead).Name: id for id in id_collection}
cdoc = CivilDocument.GetCivilDocument(adoc.Database)
with adoc.Database as db:
ppnIds = CivilDocumentPressurePipesExtension.GetPressurePipeNetworkIds(cdoc)
ppn_dict = build_dict(ppnIds)
pnIds = cdoc.GetPipeNetworkIds()
pn_dict = build_dict(pnIds)
sufaceIds = cdoc.GetSurfaceIds()
surface_dict = build_dict(sufaceIds)
t.Commit()
OUT = ppn_dict, pn_dict, surface_dict
