If i have many circles as bounding boxes inside one big square as boundingbox and i just want to know if there is a space that the circles don’t cover the square , how to do that in dynamo?
Try building a surface from the square and a solid from the circles, taking the difference of the two, and that will get you the remainder.
How to make one solid shape from many circles
Extrude as solid. Union the shapes into a single solid.
you should be able to use Surface.Boolean (union and difference) if you can do this in Dynamo sandbox 2.3
How to do it in dynamo 1.2
But is there a way to get a boolean output if the two shapes don’t cover each other
Yes there is,
Geometry.DoesIntersect
After the boolean difference, get the volume of the resulting solid. If it’s > 0 then you don’t cover.
Thank you all
