Hi ![]()
How can I save a document as a central file from dynamo using the NewProjectDocument method?
https://forum.dynamobim.com/t/create-project-files-from-template-files/14655/2?u=thomas_perkov
Hi ![]()
Found it
http://www.revitapidocs.com/2018.1/f0b5d969-3e86-b433-e2f8-a01292738c85.htm
wopt = WorksharingSaveAsOptions() #<--- here ;P
wopt.SaveAsCentral = True # <--- here ;P
sopt = SaveAsOptions()
sopt.OverwriteExistingFile = True
sopt.Compact = True
sopt.SetWorksharingOptions(wopt) #<--- here ;P
newdoc.SaveAs(path, sopt)
If youβre working with a new project, I discovered that you have to first enable worksharing before you can use the WorksharingSaveAsOptions class.
In my script, the following lines are how got it done:
for rvt in ModProjects:
open_file = app.OpenDocumentFile(rvt)
open_file.EnableWorksharing("Shared Levels and Grids","Workset1")
http://www.revitapidocs.com/2018.1/7c29717e-1d8c-4e02-20ad-65c53ea8eaaa.htm
