I am new to dynamo and trying to learn it. It the early tutorials it keeps showing the number nodes and being able to put in 0…10. Well when i put that in, it does not like that and wants a whole number. Also i can not attach a number slider for example to a number node, only the number node to something else.
Am i missing something, different node for this situation or what?
The tutorials show 0…10 then …#A or something along those lines, but my number node i can only put in whole numbers.
Show your attempts and use codeblock instead of the number node.
I am also new to using this forum so what do you mean show my attempts? And how do you use the code block?
got it. thank you very much for the help
Now what about if trying to connect an integer or number slider to the code block? Is there a way to do that?
Use a letter to define a variable.
You will have an input port in the codeblock.
I would highly recommend you to read the Dynamo Primer (we all went through it
), especially the part about CodeBlocks :
http://primer.dynamobim.org/en/07_Code-Block/7_Code-Blocks-and-Design-Script.html
