I am attempting to write a simple python script to create and open local files of multiple central files. I’m feeding the input a file path, but can’t seem to get the createlocalfile method to work. I’m sure it’s something simple since I’m new to Python, but I haven’t been able to figure it out. Thoughts?
Have you tried giving it a Full File path with File Name rather than just a directory?
API reference here:
http://www.revitapidocs.com/2018.1/205fa377-e6ad-aef0-e783-35b50152c336.htm
Yes, I have tried that (adding a \temp.rvt to the path)- no difference.
Also realized I had the wrong method name (should have been CreateNewLocal), that has been fixed and it still does not work.
Here’s what I have now…Still not working.
I get the following error on my python node:
File “”, line 38, in
TypeError: expected ModelPath, got str
What is this line doing for you:
modelPath = FilePath(file)
Since you are using the os.path.realpath above, you should be able to feed the “file” directly into the CreateNewLocal line.
I would comment out the newdoc line and set you OUT as modelPath and see what you are getting. I don’t think you need this.
It may also help if you uploaded a shot of the rest of your graph so we can make sure there isn’t something up stream causing the issue.
