Hi everybody
I am in the process of learning Dynamo coming from Grasshopper so am having a hard time wrapping my head around list operations. I hope you can be of help to understand how these list-map nodes work!
In the following screenshot it can be seen how all points are collected in one node “points”, each sublist contains a layer of points and each sub-sublist contains the points on 1 of the 4 sides of a rectangle.
I have got 4 direction vectors in the node “Direction vectors” that are matched up nicely with their corresponding sub-sublist points. (all points are now translated in their correct direction). The problem is that they are all translated the same distance.
What i am trying to achieve is that every point is translated a different random distance. How would you achieve this?
Thank you very much in advance!
Sebastian.
