Hi!
Could anyone explain how can I create a new node in Dynamo with C++; visual basic code inside? I’m trying to assign point loads in any position of a frame. For doing this there is a code in the next link that I can use.
Thanks in advance
Hi!
Thanks in advance
If you do not know how to create a Zero Sharp Node or do not know how to code in c#, then i would suggest you use the Python node in dynamo and code in python.
There is plenty of Python code on this forum to give you the guidance on Python coding that then should give you a starting point to code this Create point load yourself.
