Beginning with Dynamo i’m stuck trying to access data in a nested list.
I have a nested list structured this way :
8 main lists, each list with 12 lists inside, then 5 lists inside and 4 points inside each. I’m trying to reach each point referred at index 0 at the end of the nested lists. In Grasshopper I’ll did this with a list item component, but as the GetItemAtIndex works “like” a Grasshopper Branch component I don’t understand how to manage this, I checked the Dynamo Primer but I don’t find any solution even with the List.Combine component, that I may not be using properly.
Thanks in advance !
