Nested if in Code Block
Any idea why it did not show as expected.
and.dyn (18.4 KB)
In your first code block is x<6 and x>7 but then in your design script you have both with “<” signs.
Ahh…i will change and try…
But the and or node gives null…any idea?
The code block worked as expected. But Node hives Null
strange, you tried to disconnect reconnect
Nope…not working for me. :upside_down_face:
However, i got an alternate soluation with code blosk as above.
try to open to see if same result with attached file
and_v2.dyn (12.1 KB)
Same,
grr, sorry for not being up to solving your problem, you have a palliative so it should be fine nevertheless, good luck @ you
Cordially
christian.stan
Thanks mate for help.
