what is the meaning of below code Block
top line:
of “len” input is bigger(or equal) than/to 5 “elem” is returned else “null” is returned…
Bottom line:
“false”
Generally you should not use logic you do not understand, you should rather write your own graphs…
Thank you brother. is there any alternative way to write this
The ScopeIf+ node is from the Clockwork package. Mind the lacing being changed to “longest”
Top Line
Bottom Line
thank you for your help
