Need help with Python - FillPatternElement
Hello!
I have a problem with my script Python. I need to collect the solid pattern to apply it in a view. But I have an error, and I don’t see where it’s come from.
I find this code on different forum:
patternsList = FilteredElementCollector(doc).OfClass(FillPatternElement)
solidPatternID = 0
for p in patterns :
pat = p.GetFillPattern()
if pat.IsSolidFill == True:
solidPatternID = p.Id
But Dynamo tell me:
“Avertissement:IronPythonEvaluator.EvaluateIronPythonScript l’opération a échoué.
File “”, line 73, in
Exception: Input type(Revit.Elements.FillPatternElement) is not a recognized Revit API type
Parameter name: type”
Do you have an idea to resolve that ?
Thank you for your help
PS: Sorry for my bad english (it’s not easy for me to explain my problem with a different language)
@Melanie_V ,
can you paste your code ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
OUT = element
Thanks for your answer.
There is my code :
import sys
from Revit.Elements import *
dataEnteringNode = IN
valuesList = IN[0]
paramID_Debut = ElementId(IN[1])
paramID_Fin = ElementId(IN[2])
paramID_Chantier = ElementId(IN[3])
filterNameList = IN[4]
myView = UnwrapElement(IN[5])
optionDuplicate = Autodesk.Revit.DB.ViewDuplicateOption.WithDetailing
paramElem = doc.GetElement(paramID_Debut)
definition = paramElem.GetDefinition()
binding_map = doc.ParameterBindings
binding = binding_map.Item[definition]
category_set = binding.Categories.GetEnumerator()
cat_ids = [cat.Id for cat in category_set]
cat_ids_list = List[ElementId](cat_ids)
cat_ids_valid = ParameterFilterUtilities.RemoveUnfilterableCategories(cat_ids_list)
pStart = ParameterValueProvider (paramID_Debut)
pEnd = ParameterValueProvider (paramID_Fin)
pChantier = ParameterValueProvider (paramID_Chantier)
FiltersList = list(FilteredElementCollector(doc).OfClass(ParameterFilterElement).ToElements())
FiltersName = [i.Name for i in FiltersList]
mesFiltres = []
red = Color(255,0,0)
solidPatternID = 0
for p in patterns :
for myValue in valuesList :
	phaseEnCours = filterNameList[0]+str(myValue)
	postPhase = filterNameList[1]+str(myValue)
	newViewID = View.Duplicate(myView, optionDuplicate)
	newView = doc.GetElement(newViewID)
	try :
		newView.Name = myView.Name+"_"+str(myValue)
		mesFiltres.Add("Vue créée : "+newView.Name)
	except :
		mesFiltres.Add("Vue non renommée : "+newView.Name)
	if phaseEnCours not in FiltersName :
		xStart_enCours = FilterElementIdRule (pStart, FilterNumericLessOrEqual(), ElementId(myValue))
		xEnd_enCours = FilterElementIdRule (pEnd, FilterNumericGreaterOrEqual(), ElementId(myValue))
		xrule_enCours = []
		xrule_enCours.Add(ElementParameterFilter(xStart_enCours))
		xrule_enCours.Add(ElementParameterFilter(xEnd_enCours))
		ruleList_enCours = List[ElementFilter](xrule_enCours)
		myRule_enCours = LogicalAndFilter(ruleList_enCours)
		filter_current = ParameterFilterElement.Create(doc, phaseEnCours, cat_ids_valid, myRule_enCours)
	else :
		for f in FiltersList:
			if f.Name == phaseEnCours :
				filter_current = f
	newView.AddFilter(filter_current.Id)
	over = newView.GetFilterOverrides(filter_current.Id)
	over.SetSurfaceTransparency(0.0)
	over.SetCutForegroundPatternColor(red)
	over.SetSurfaceForegroundPatternColor(red)
	newView.SetFilterOverrides(filter_current.Id,over)
	mesFiltres.Add(phaseEnCours)
OUT = mesFiltres
It’s possible that FillPatterns are not a valid class for the FEC. You can always get this list in Dynamo using Element Classes and All Elements of Class.
