I came across this (what I’m guessing is C#) code for creating a new line pattern type.
https://forums.autodesk.com/t5/revit-api-forum/create-line-pattern-type/m-p/3682176#M3293
I’m trying to put this in a Python Script node for use in Dynamo. I simplistically started with:
patternName = “test”
linePattern = LinePattern(patternName)
LinePatternElement.Create(doc, linePattern)
I’m sure it is obvious to many why this doesn’t work. The error indicates the Line Pattern is invalid parameter name linePattern. I assume that means my attempt at assigning linePattern = is wrong. Hoping someone can get me going in the right direction.
Hi @nelson.weeks,
If you translate the C# code snippet into python this gives :
clr.AddReference('RevitAPI')
patternName = IN[0]
#Create list of segments which define the line pattern
lstSegments = List[LinePatternSegment]()
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Dot, 0.0));
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Space, 0.02));
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Dash, 0.03));
linePattern.SetSegments(lstSegments)
#Create a linepattern element
linePatternElement = LinePatternElement.Create(doc, linePattern)
OUT=linePatternElement
@Alban_de_Chasteigner thank you for the response! Did you use the “Convert Code to” tool in the Macro Manager environment to translate?
I didn’t think about it.
The Python syntax is different in the macro environment.
I see, you used your knowledge of both C# and Python to make the translation. I asked about the “Convert Code to” because I attempted to do that, but couldn’t make the result work. Thanks again!
I refined the script and created a node.
Pretty cool. At the risk of sounding greedy, it would be more useful for the node to take a list of Types and Lengths because every linepattern doesn’t have the same number of segments.
I will not do a node with more than 21 inputs
You can use the lacing longest if your line pattern is repetitive with input lists.
This is what I had it mind…inputting lists of pattern names, segments types and lengths (varying number of segments from one pattern to next). I appreciate @Alban_de_Chasteigner for getting me started on the right path. I’m open to any ideas on how to improve it further.
from Autodesk.Revit.UI import TaskDialog
patternName = IN[0]
segTypes = IN[1]
segLengths = IN[2]
#counter for number of patterns to create
j=0
#iterate through each pattern and create
for j in range(len(patternName)):
pattName = str(patternName[j])
#counter for segments in current pattern
i=0
#Create list of segments defining the line pattern
for i in range(len(segTypes[j])):
length = segLengths[j][i]
strLength = str(length)
#determine current segment type and add to list of segments for current pattern
curSegment = str(segTypes[j][i])
if curSegment == "Dash":
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Dash,segLengths[j][i]))
elif curSegment == "Space":
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Space,segLengths[j][i]))
elif curSegment == "Dot":
lstSegments.Add(LinePatternSegment(LinePatternSegmentType.Dot,segLengths[j][i]))
linePattern = LinePattern(pattName)
OUT=[]
Hi Nelson,
You’re absolutely right that the node can be improved.
I’m not an expert in python but you can probably simplify your code.
Take a look at the new version of the node.
@Alban_de_Chasteigner Hi Alban, i am totally new to Python and i tried to copy the code from Nelson’s post but it didn’t work.
can you share with me the code of this new version of the node?
Hi Hassan,
You can find this node in the Genius Loci package.
i tried to add numbers from excel sheet and here comes an error
Hi Alban, old topic here but do you have a technique for retrieving the line pattern segment definitions. I’ve got as far as the GetSegments Method for LinePattern but cannot find how to see the lengths of the dots, dashes and spaces etc.
Thanks in advance
