Hi All,
I have created a script to generate a family at a specific set of coordinates referenced in an excel file.
However I primarily use mm within Revit and when I export the coordinates in mm to excel, I get an error message in dynamo stating I am too far past the projects coordinate system, which is 1,000,000 or something. I checked all of the points in mm and none of them exceed xxx,xxx.
The script works file if I first set my units in Revit to meters and have the excel in meters. But this will cause issues as everything else I work in is mm. I have attached a screenshot of the dynamo script below.
