Need Help with Dynamo – Create Area Boundaries from Room Boundaries
Hi Team,
I am currently stuck while trying to create Area Boundaries from Room Boundaries using Dynamo.
The issue seems to be with the AreaSeparator.FromCurve node. It looks like a SketchPlane is missing or not being recognized, and because of this I am unable to create the Area Boundary lines. The node keeps returning null, and I am not sure what is causing the problem.
If anyone has encountered this issue before or can suggest a solution, I would greatly appreciate your help.
Thank you in advance for your support.
I just reproduced your graph, and it seems, correct me if I’m wrong, the Area.SeparatorFromCurve node is a Clockwork node? You should really use the monocle package to add text nodes in graphs to highlight non-ootb nodes.
Anyhow, it gave me the same result. However, with the Pickles package, from the great Gavin Nichols of Aussie bimguru fame, it can be done. At least in Revit 2027.3. The name of the node is Pkl_Area.CreateAreasFromRooms.
First view is the “normal” plan view, second one is the area plan view. As you can see, with the monocle package, it is easy to highlight the non-ootb nodes, which can be really helpful to understand shared scripts, or maintain them in the future. monocle>package usage>package usage doge>Annotate Custom Nodes (add note).
Thank you so much! That worked perfectly.
