NameError: name 'y' is not defined
Hello All,
I have put to floor plan view on the sheet by using python but one error massage is coming. Error massage attached in below:
Also I have attached my created python script. Please have look on this.
#Put View on Sheet
clr.AddReference('RevitAPI')
sheets = IN[0]
views = IN[1]
x = IN[2]
Y = IN[3]
viewsplaced = list()
TransactionManager.Instance.EnsureInTransaction(doc) # you need an active transaction as you will create elements
for number in range(len(sheets)):
    sheet = UnwrapElement(sheets[number])
    view = UnwrapElement(views[number])
    Viewport.Create(doc,sheet.Id,view.Id,XYZ(x,y,0))
    viewsplaced.append(view.ToDSType(False))
Out = viewsplaced
Thanks,
Looks like you have defined Y = IN[3] bit I think you wanted y = IN[3] instead.
Thank You Jacob. Problem solved.
