Name Error: Autodesk not defined
Hi there,
I amt trying to run Naviswork via Dynamo, similar to Dynawork node. I need to do this to add some customized options to it. I can successfully run it from Visual Studio as a C language program. Though, when I try to do the same w.r.t. Python it is giving me an error: ‘Autodesk’ no defined. Any suggestions?
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
nav_path = r'C:\Program Files\Autodesk\Navisworks Manage 2020'
sys.path.append(pyt_path)
import os
import io
import System
try:
	from Autodesk.Revit.DB.Structure import*
except: pass
try: #try to import All Revit dependencies
	from  Autodesk.Revit.UI import Selection , TaskDialog
	from  Autodesk.Revit.UI.Selection import ISelectionFilter
	clr.AddReference('RevitAPI')
	try:
		from Autodesk.Revit.DB import ImageImportOptions
	except:
		from Autodesk.Revit.DB import ImageTypeOptions , ImageType, ImagePlacementOptions , ImageInstance
	from Autodesk.Revit.DB import FilteredElementCollector , Transaction, View , ViewType , ViewFamily, ViewDrafting, ViewFamilyType, Element, ElementId , FamilyInstance , Document , XYZ, BoxPlacement, UnitUtils
	try: #Naviswork dependencies
		from nav_path import *
		#from nav_path import Autodesk
		clr.AddReference('Autodesk.Navisworks.Api')
		clr.AddReference('Autodesk.Navisworks.Automation')
		clr.AddReference('Autodesk.Navisworks.Controls')
		from Autodesk.Navisworks.Api import *
	except: pass
except: pass
filepath_nv = IN[0]
nv_visbility = IN[1]
nwapp = Autodesk.Navisworks.Api.Automation.NavisworksApplication();
doc = nwapp.ActiveDocument
OUT = doc
You are trying to import the Navisworks and Revit api, but if it fails just passing onto the next aspect of the code. Instead you need to surface the error, or simply remove the try/except statement (which is the preferable option in my opinion).
try replace this
with
nwapp = Automation.NavisworksApplication()
this article can help you
This works! @jacob.small Thank you!
This helps, thank you for the link @c.poupin !
