My current script will receive a list of strings and when a string value is equal to IN[2] (or IN[3]) then the value will be replaced with "NULL". And yet if I define a variable with the desired value ( Weld1 = "307623") with the same value that I define in a code block. It does not work. And no error message either. I am completely stumped on this one. It was my understanding that if I define Weld1 = IN[1], which IN[1] is wired to a code block with the contents of "307623", then that would be the same as if I define
Weld1 = "307623"
Here is my code below. The IN[0] is a list of strings that all portray the Type Id value of items in revit.
clr.AddReference('RevitAPI')
clr.AddReference("ProtoGeometry")
from RevitServices.Persistence import *
from RevitServices.Transactions import *
clr.AddReference('DSCoreNodes')
import DSCore as DS
from DSCore import *
#import sys #clr.ImportExtensions(Revit.Elements) #from Revit.Elements import * #clr.ImportExtensions(Revit.GeometryConversion) #from Revit.GeometryConversion import * #clr.ImportExtensions(Revit.GeometryReferences) #from Revit.GeometryReferences import * #import System #from System.Collections.Generic import * #from System import *
####### Trying to remove the specified values from IN[0] list
######Step 1: Get all indices of values present in current list
#####Step 2: Remove Items at said Indices
lost=IN[0] #List of parameter values to
#list = lost
#ShortList=IN[1] #list of string values
str1=("307623") #value to remove from list
#Weld1 = str1
str2=("308609") #value to remove from list
#Weld2 = str2
#strs = str1.Append(str2)
cnt=len(lost)
inx=0
num1 = []
num2 = []
indices=[]
Output = 0
x = 0
#Weld1 = IN[2]
Weld2 = IN[3]
Weld1 = "Type Id : 307623";
#Weld2 = "308609"
rep = IN[1]
elementlist = list()
for item in lost:
if item is Weld1:
item = rep
elif item is Weld2:
item = rep
elementlist.append(item)
#str3i = str1i + str2i
#output = List.RemoveItemAtIndex(list, indices);
#NewID = [A,B,C,D,E,F,G,H,I,J,K,L,M,N,O,P,Q,R,S,T,U,V,W,X,Y,Z];
#if NewID==(0):
# List.RemoveItem
#List.RemoveIfNot(NewID, (>=0));
OUT = elementlist
I apologize for all the comments in my code.
